Hi,
I am having problems installing the plumbing to the Facet electric fuel pump from VANs and am trying to see how people have solved this issue. Unfortunately most of the threads i read are about high pressure fuel pumps for IO engines. I am installing a O- engine. There is not enough space at the bottom where we are to connect the fuel line to the inlet of the fuel pump. I also read that it is a good idea to install a fuel filter, VANs does not show that. So any tips or pictures would help.
Thank you all.
Thank you all.
