I am following the revised FAB instructions for the O-320 in my RV-9 but finding them a little scarce on detail, particularly the drawings. For instance, no drawing (or text for that matter) shows the orientation of the flush rivets through the carb heat door assembly. Is it countersink head up or down?
I know I am supposed to be a big boy now that I have reached FWF but it seems I still need my training wheels a little bit longer. The only justification I can think of for countersunk rivets here is for smooth airflow across the underside of the carb heat door. However, that’s hardly important when the forward edge of the door presents a step at least 1/16th thick and causes turbulent airflow there in any case.
I would prefer AN470-AD3 as used to rivet the bowl edge to the top plate. They seem to me to be stronger, especially when the instructions call for the shop head to be under-set.
Any thoughts?
Any thoughts?
