"The FAA last week ended its suspension of amateur-built aircraft kit evaluations, which had been in effect since February 2008. The FAA had put the kit evaluations on hold while it worked on a revision of its interpretation of the "51-percent" regulations that govern amateur-built aircraft."
The whole article can be found from AVWeb at http://www.avweb.com/eletter/archives/avflash/1464-full.html#201200
