When it came time to put the panels on the inside, I realized that I didn't have any cover for F-14106.
I guess a lot of builders put fuses there, but I opted for breakers on the panel.
As it goes, Van's does not have a template or part for this cover, so I carefully measured and after many revisions came up with the template below:
https://rv-14-parts.s3.amazonaws.com/WiringChannelCover.pdf
Just putting it here for other builders in case they need it.
Make sure you don't scale it when you print, and check the dimensions!
