Lord J-7764-31 are the aerobatic engine mounts. I purchased mine from Herber. The others are J-9613-12. I'd recommend the aerobatic ones, although the cost is higher.
Maule 540 numbers
The parts used in the Maule 540 are good parts - could be one of those that Mark mentioned? If I could recall the right number, I would tell you...
Lord mounts
Just replaced mine in Rocket s/n 097
Lord P/N J-7764-20
Same as Lord mounts for the Extra aircraft.
Cheers.
