TASEsq
Patron
Hi,
I’m completing the riveting of the doubler to the HS rear spar, and the plans call to leave a group of 6 holes on each side un-riveted.
Here are the holes - the 6 blue holes are where you rivet the inspar ribs later on, and the 6 red holes are where the F01411C bulkhead bars attach later (on the forward side of the HS rear spar / bulkhead: https://photos.app.goo.gl/HB6WXBUtGodBq3h89
The attach method is to updrill 4 of the 6 red holes to 1/4 and a AN4 bolt is used. Here is the image from the instructions https://photos.app.goo.gl/8Cp88QBfkqTFJNe59
There is also 3 matching holes in the F01411C attach bars (photo here https://photos.app.goo.gl/Ap4GfH8sSxF1PXgJ9)
Question - what happens to the middle hole??
I can’t find where anything further is done to this hole? (Or am I missing something?)
Should a countersink the doubler and install an AN426 flush rivet? Or leave it as it is? Maybe updrill all 6 holes and use 6 bolts instead of 4?
I am assuming this hole was used in the RV10 and I think it might be the same HS rear spar.
Thanks in advance
Greetings.
See page 11-05, Step 1, Figure 2. Those holes are for clecos to secure the HS for the final drill tasks you cite on page 11-06 (it's similar to the hole on the VS for the same purpose on page 10-28). They are not used for later securement.
You can see clecos in those holes where when I did my initial empennage attach. Front side, harder to see:
Back side during drilling of elevator horns. You can see the pins of the clecos in place:
Finally, here are those holes (unfilled, per plans) in my plane after it had been flying for 29 hours (decided to put Spirap on the elevator trim wire):
Ok, thanks very much.
Glad I?m not going crazy.
I suppose that is easier than using bolts in 2 while you updrill the other 2 (although that seems a sensible procedure to me).
