BoilermakerRV
I'm working on the forward covers. There are three holes detailed on the F-982E access cover (throttle, mixture and carb heat). I'm planning on a pretty standard engine install, with the probable exception of a CS prop. Just curious if I should go ahead and fab per the drawing or wait until my engine/prop is a little more firm.
Definitely wait until your engine/prop is firm. I have the IO360 M1B from Vans and only the mixture control goes there.
