rapid_ascent
I'm curious if the F-745 that is mounted to the sub-panel should stay in the position described in the instructions even if the panel has the engine controls shifted to the right and in my case lowered due to the modular Affordable Panels lower switch panel.
It seems like the F-745 should be positioned such that it is directly forward of the engine controls. Is this a requirement? I'm not sure it is tall enough to allow this given my switch panel lowers the engine controls approximately 2".
I'm curious how these pieces must be aligned. Any comments on what others have done would be helpful.
