Sid Lambert
Hello again all,
I have a question about where the F-623A actually goes. If you look at the plans (22 C-C), the drawing appears to me that he 623 is on the outside or not even under the seat back bulkhead. I'm not sure how the strap even does anything. Is the strap more of a doubler and not a strap? Do I need to trim the flange of F-623 so it fits between the skin and
From the bottom skin up, the order appears to be:
Bottom center skin, bulkhead flange, 623, 623A. Is this correct?
Does anyone have an good pictures of this assembly? Or a good description of it?
Thanks all.
seat back
bulkhead?From the bottom skin up, the order appears to be:
Thanks all.
