llohrman
Member
Anyone remember if they had to trim F-615, F-616 and F-617 (left and right) seat ribs. The aileron push/pull tube rubs on the forward edge of the lightening holes with the stick in the elevator up position. I have trimmed F-618 and F-619 per plans for the control stick weldment but couldn't find anything on the others.
Thanks!
normal to clearance large lighting holes for slight interference of aileron control tubes, if you need to remove more than 1/8" or so you may want to recheck the mount height of the controls to spar mount bracket.
