I'm in the planning stages (for many months) of a panel upgrade in my RV6.
In a thread on replacement panels from a couple months ago, Paul Dye and Mike Starkey recommended that a DIY approach was well worth it, and that it wasn't necessary to hire out the panel cutting to someone else. I'm going to give it a try. I may order an extra blank or two though...
I'm not sure which panel blank I need. The plane currently has an F-603 panel, which is 11" tall. I want to keep that format. Searching F-603 on the Van's site only yields the F-6103 OVSZ. Per the description, F-6103 OVSZ can be used in the 6, 7 and 9 tip-ups, and measures 14"x42", but has a (confusing) Q&A response stating it is 11"x42" (see the picture).
The F-703 description only shows the 7 and 9 tip ups.
Can I use the F-703 in a tip-up RV6?
I've been told some trimming/shaping is required no matter what I get, but it seems like if the F-6103 OVSZ works in the 6, 7 and 9, then F-703 would too.
I'm planning to give Vans a call later today, but thought someone here might be able to help.
