Michael Burbidge
On the right inboard seat rib I installed the routing angles with the flange to the rear, instead of to the front as is shown in the diagram on page 26-04.
If I don't have to, I'd prefer not to drill these out. From the drawings it doesn't look like it matters. But you never know. Can someone with a finished or near finished build tell me if it matters?
Michael-
I truly cannot see how it would make a difference. Only holding plastic bushings.
On a side note I made some extra brackets in the lightning holes to facilitate more wires running from the wings to the centre fuselage tunnel. You will likely need more or something similar to what you have now.
