When using the Touch screen for en route flight planning, the A/P will disconnect from the nav mode to Roll when you switch from external to internal navigator (and back to external). Is there a way to configure the system so it will remain coupled to the A/P nav GPS when you toggle back and forth between external/internal on the G3X touch or is it what it is. The external nav is a GTN and the autopilot is a 307.
