david.perl
Im fitting a dynon SV and wondered if there is a need for external warning lights? I see others have fitted these - does the SV not display warnings?
I have found that with single efis panels, the external annunciators make a lot of sense. The amount of room for engine and annunciators info on the efis makes it difficult to scan.
Also, you do not always want an alarm on status lines --fuel pump, pitot or smoke comes to mind.
It is easy to control the lamps with one of the annunciators controllers from MakerPlane, which support dimming and testing of any lamp polarity.
There is no reason not to connect the audio, it does a good job announcing any of a host of alerts. I have had an oil pressure sensor become erratic over the last month. Having Betty say loudly "Oil Pressure" does get your attention at least as well as another light on the panel. Sensor replaced today, all is well.
Do you absolutely need it? No. But in my opinion it is a very good to have. The regular SV indication is in the bottom right part of the screen and, unless you have the audio also connected, easily overlooked.
I placed external annunciators above the SV display in my regular line of sight/scan area. Amazing how quickly it brings your attention to the alarm.
My 2 cents.
Modern avionics reflect much thought and research in their human factors design. Embrace it.
Make sure you can turn it off, it you add it.FWIW, I designed a half-dozen external annunciators to have high on my panel, but am not going to install them now I've seen the true capabilities of my SkyView/VPX system. It is hooked into the audio so I get voice warnings as needed. That being said, I'll probably have one really bright red LED in my line of sight.
And incidentally, proper alarm annunciation involves both a visual and audible component, not just a visual one.
The SV and I assume the others allow you to acknowledge the alarm and kill the light and silence the alarm.
