Has anyone installed the XL panel? I believe it extends down 1 3/4 inches farther. Has it cause any issues with leg room? I am thinking about doing that so I have room to stack my EFIS and EMS.... Ken
I have the slider as well. Thanks for the input! I will start punching holes tomorrow. Headed to Arizona to go pick up my motor and prop in a week so things coming alone great! Thanks again! Ken
I used the oversized panel and have no problems at all. I have the tip-up so there is less of an issue getting behind it, but with an EFIS and a EMS high up on the panel, access down lower is restricted.
On my extended panel with a military stick grip I had to shorten the control stick quite a bit to keep it from hitting the panel switches when I swept the cockpit with the stick.
