This is a little different, no a lot different. I'm talking about flying into known icing conditions, deicing on the ground, ect. Are there FARS that govern this with experimentals?
With experiments we can't just fly any way or any where we want.
For instance:
Sec. 91.527 ? Operating in icing conditions.
(a)
No pilot may take off an airplane that has frost, ice, or snow adhering to any propeller, windshield, stabilizing or control surface; to a powerplant installation; or to an airspeed, altimeter, rate of climb, or flight attitude instrument system or wing, except that takeoffs may be made with frost under the wing in the area of the fuel tanks if authorized by the FAA.
(b) No pilot may fly under IFR into known or forecast light or moderate icing conditions, or under VFR into known light or moderate icing conditions, unless?
(1) The aircraft has functioning deicing or anti-icing equipment protecting each rotor blade, propeller, windshield, wing, stabilizing or control surface, and each airspeed, altimeter, rate of climb, or flight attitude instrument system;
(2) The airplane has ice protection provisions that meet section 34 of Special Federal Aviation Regulation No. 23; or
(3) The airplane meets transport category airplane type certification provisions, including the requirements for certification for flight in icing conditions.
(c) Except for an airplane that has ice protection provisions that meet the requirements in section 34 of Special Federal Aviation Regulation No. 23, or those for transport category airplane type certification, no pilot may fly an airplane into known or forecast severe icing conditions.
(d) If current weather reports and briefing information relied upon by the pilot in command indicate that the forecast icing conditions that would otherwise prohibit the flight will not be encountered during the flight because of changed weather conditions since the forecast, the restrictions in paragraphs (b) and (c) of this section based on forecast conditions do not apply.
[Doc. No. 18334, 54 FR 34314, Aug. 18, 1989, as amended by Amdt. 91?310, 74 FR 62696, Dec. 1, 2009]
John Clark ATP, CFI
FAAST Team Representative
EAA Flight Advisor
RV8 N18U "Sunshine"
KSBA
