BlackRV7
Over this past first flight weekend, my Garmin 430 decided to go and smoke itself. Everything worked on the unit except the mic. It would open the circuit but no voice from the mic. We went from pilot to pasenger side, push to talk, the whole gambit of possibilities. No joy.
Well, me being the total electrical knowledge derelict, I just knew it had to be some of my wiring. Crawling under the panel offered no views of smoked, burnt, blacken or loose wiring. Hum, me be thinking but also Hum, this is going to be difficult to find. Mike has a 430 in his Super 8, so I removed mine in order to put it in his, just to check the unit itself. Upon pulling mine out, I could distinctly smell that burnt electrical odor coming from the plug in the back where the mik plugs in from the intercom. Into the Super 8 it went, same result as in mine. OK, I may still have to chase wiring down to find the source but at least we know the unit is bad.
After thinking about it a little more, I went to the airport yesterday and retrieved the 430. When I got home, I opened the top to see if I could see the damaged area. I didn't have to look very long. The burnt board area was just under the MIC GAIN hole in the top cover plate.
Here is the lesson: Lying on top of the burnt area, and another one close by, were two aluminum slivers................ One of the first pieces to go in my panel was the 430. Sometime during the building process I had cut a new hole, done some trim work, done some deburring, whatever, and not covered this hole up. One of these aluminum pieces turned into a conduit for 12v where it wasn't supposed to be!!
Result of my lesson learned: The flat $700.00 fee from Garmin. Since we are experimental, I had to get an RMA number from a local avionics shop. I can still ship the unit myself back to Garmin, but Garmin will only ship it back to an authorized dealer. No problem for me, as my FBO has an avionics shop about 30 miles away at LEX. Just out the bucks.
Lesson: vibration will bring things to the forefront when you least expect it........especially when I/you are an idiot and get in to big of a hurry and stop thinking momentarily![Roll eyes :rolleyes: :rolleyes:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
