Found on Web........
Can you tell us the source of the photo that you posted? I would like to know what it says about some of the other engines.
Avco Lycoming
Note: 0-235 thru 10-540 Lycoming engines built between 1970 and
1981 may contain sintered-iron oil pump impellers. As a result, such
engines maybe subject to AD 81-18-04, which requires replacement of
iron impellers at 2,000 hours. If you have sintered iron oil pump gears
in your engine, no attempt should be made to "bust" TBO. Such gears
are a definite hazard and should be removed as soon as practicable.
0-235-C/E/H: Where solid-stem exhaust valves and bronze guide
are used, expect to achieve recommended TBO (2,000 hrs.) only with
difficulty. Solid-tappet engine requires frequent valve adjustments to
make TBO. Plain-steel jugs (not nitrided) give average wear. Chroming
not recommended (rings not available). Lead buildup can be
evere with high-lead fuels.
0-235-L2C: Nitrided cylinders and sodium valves give good longevity, but
solid tappets require careful valve maintenance, and use of
high-lead 100 "green" gas may shorten top-end life. (TCP will help,
though.) Chroming of cylinders not recommended, due to unavailability
of suitable rings.
0-320-A/C/E: Engines built before 1967 may have 7/16" exhaust
valves, in which case the recommended TBO of 1,200 hours should be
adhered to. Because these engines do not tolerate lead well, Lycoming
advises restricting use of "green" 100-octane gas to 25 percent of total
operating time or less. With TCP and use of 1 /2" valves, a 2,000-hour
TBO can be met or exceeded (except aerobic engines). Nitrided cylinders
not available for -A models.
0-320-B/D: High-compression versions of -A/C/E models which
tolerate lead better. However, high-time cylinder heads are apt to
develop small cracks. The jugs may either be chromed or nitrided and
thus wear good. First-run cylinders can easily exceeded the recommended
2,000 hours.
0-320-H: Unless the large-tappet, large-cam T' mods have been
done (indicated by a suffix 'T on the serial number), tappet spalling
may be encountered en route to TBO, even if Lycoming oil additive
LW-16702 is used. Because of this risk, it is advisable to adhere to
factory TBO (2,000 hours)-and convert to T' configuration as soon as
possible.
IO-320-C1A: These engines have $358 Inconel exhaust valves (to
accommodate turbocharging). With proper care, the 1,800-hr TBO can
be exceeded. (Nitrided jugs give good service life.)
0-360-E: Early versions of these engines incorporated same tappets
and camshafts as 0-320-H (see above). Same caution applies.
0-360-A/B/C/D: These are arguably Lycoming's finest engines (for
long, reliable service). With nitrided cylinders, and assuming all
bulletins/ADs are up to date, expect 2,600 hours TBO; 3,000 for first
run engines.
TO-360-C/F: Cooling problems caused by a relatively poor match of
turbocharger to engine gives these Lycomings a factory TBO of 1,400
hours-which is probably a good idea not to exceed.
IO-360-B/E/F: Members of the 180-hp 10-360 group have chromestemmed
sodium exhaust valves and nitrided cylinders, and a generally
stone-solid bottom end. These engines very often exceed the
recommended TBO of 2,000 hours.
IO-360-A/C/D/J: The 200-hp 10-360 family uses plain (not chrome stem)
sodium valves. A variety of crankcases can be found. Cases with
small main-bearing dowels should not be run past 1,200 hours
Engines with large dowels and old-style camshaft should not exceed
1,400 hours. Late-style engines (with latest cam) can go 1,800 hours or
more, but watch for crankcase cracks.
TIO-360-A: Different turbo, controller, and fuel metering system
from TO-360 series, but still not a good combo for long engine life.
Factory TBO of 1,200 hours should be respected.
AIO-360: Aerobatic engines in this group can go a maximum of
1200 hours between overhauls (or 1,400 if derated to 180-hp).
However, a less optimistic figure probably ought to be chosen if more than
occasional aerobatics are performed.
GO-435: Many owners claim they make it beyond the 1,2UU l BU.
This engine is particularly sensitive to operator technique.
GO-480: Engines modified i/a/w applicable bulletins (e.g.: S.I.
1182A on high-lift rockers and late-style cam) and incorporating
sodium-filled valves can exceed the 1,400-hr TBO.
Teledyne Continental
0-200-A: Recommended TBO is 1,800 hours. With close adherence
to bulletins and use of low-lead or unleaded fuels, TBOs much higher
should be routine. Basically a viceless engine whose potential is
limited only by exhaust-valve (and guide) life.
0-300: Average engine makes TBO (1,800 hrs.), but many are now
old and tired and can look forward to cracking problems, with both
heads and cases. Valve sticking can occur with high-lead fuels,
particularly as bronze guides wear out.
GO-300: Geared version of 0-300. Higher rpms lead to hotter
operation (definitely a drawbacks). Spur gear at front of case needs
attention after 1,200 hours. Crankcase cracks are possible.
TBO-busting not recommended.
E-185/225: Basically early 0-470s with parallel-valve heads and
three-ring pistons.These engines do poorly on high-lead fuels. But can
make the recommended 1,500 hours if 80-octane or unleaded autogas
is used. Not a good candidate for TBO-busting. Frequent exhaust
valve problems.
10-360 Engines made before 1976 should not be run past the
recommended TBO of 1,500, unless updated to latest configuration
(An improved crankcasebecameavailableinl976.Heaviercrankshaft
started in 1979. Numerous other changes have been made as well.)
1 0-360-KB: Continental says 2,000 hours. (The 'B' models have the
heavy crank.) Users agree.
TSIO-360-A/B/C: Factory TBO of 1,400 hours should probably be
raised to 1,600 or 1,800 (at least for fully updated models, with - B crank
and late case). Watch exhaust valves for necking, burning.
TSIO-360-E/F/G: These engines are hot-running (due to fixed
wastegated Rajay turbo) and hard on pistons. Watch for valve
burning, rocker bushing wear, and tach drive breakage.
Significant service bulletins affect turbo, mags, oil pump,
and crankshaft. Not a good candidate for TBO-busting.
(Factory says 1,800 hours. That should probably be revised downward.)
0-470. Exceptionally strong "bottom end." Low compression ratios
(and power output) translate to long engine life. Good candidates for
TBO-busting if low-lead fuels (and TCP) are used. Many operators
exceed 1,500-hrTBO. Watch for exhaust valve necking, burning, guide
wear.
10-470. With "heavy" cylinders, another good candidate tor exceeding
the factory's 1,500-hr TBO. Again, exhaust valves must be
watched closely.
