I think it is important to turn off the GPS once in a while and do some good old pilotage jsut to remember how.
And what ever you do, don't rely on GPS in the mountains, especially if it does not have a good terrain presentation. Without the terrain they can and have led people to their deaths in what turned out to be the wrong canyon...
I confess....
I love GPS, and most likely will leave it on. I've been using moving map versions since the early ninties when they became available. It's true, that the simple black line versions of the past have contributed to mountain accidents. Of course, these days, GPS with terrain data-bases can be had for cheap. I use a Garmin 696, but have a Lowrance 600 that I picked up for $299 when they were on sale. They are about $499 these days.
As far as using GPS in mountain areas, they do work great. You'd have to be in an awful narrow canyon for it not to work. And if the GPS has a half decent moving map, you'd never end up in that canyon to start with. About five years ago, a Mooney took off from the airport next to my home. Clouds were half way down the mountains; but the pilot, who was un-familiar with the area, figured that he could follow the freeway to clearer skies in the distance. Unfortuantely, he followed the wrong road as the freeway curved, and ended up in a blind canyon. It was fatal. In this case, a moving map GPS would have probably saved his rear. And the same for two other accidents in this area, that had flight instructors on board. Both had GPS's; but of the older black line variety. Both hit mountains by using a direct course, and not checking the minimum altitudes first.
My GPS (696) is great! The terrain map automatically turns on when getting close, and a female voice says "terrain - pull up, pull up"...
As far as pilotage goes, I practice that too. Afterall, I live and fly in a very mountainous & rugged area. Flights need some advance preperation when flying around here. IMO, just leave the GPS on. At least I do, because I don't believe in the "old fashioned way"............anyway.
L.Adamson --- RV6A
