I sent the following message to Gus at Van's about an error on page 45-07. The picture is correct on the plans. The instructions are in error.
Gus,
On page 45-07 step 2, it calls for the ES diode master and P154 wire to be hooked up to the same post on the master relay. That should read P150. The P154 wire is hooked up to the other post that does not have the diode. I checked another RV and that is the way it was hooked up.
Gus,
