pilot28906
Where are the locations of the two ( left & right) firewall pass through holes on the upper firewall? The ones used to run the EGT/CHT wires into the cockpit. I can not find those on any drawing but see most folks have added one on each side of the firewall up high.
Thanks for the info!
Wherever you want. The plans don?t specify.
That said, most put them right up near the left and right mount attach locations since the mount itself can then provide routing for the wires. Good luck.
Carefully consider the right location and potential interference with battery removal and replacement.
