I have a new Aero Sport Power engine with 18 hours on it with a carb and fixed pitch prop. Engine is a O-360-A2A. Engine and prop were dynamically balance to .04. I have one Slick 4373 on the left and a Lightspeed Plasma II with a crank censor for the other ignition.
During flight if I switch off the mag the engine runs smoother or if I switch off the Lightspeed the engine runs smoother on just the mag. My cylinder temp run about 315 degrees (all are within 4 degrees of each other) and the exhaust temps are fairly close. The outside temp is around 75 degrees F.
I also have a problem with the oil temp as it will climb over 220 degrees if I do not throttle back to 2200 to 2300 RPM. The oil cooler is the standard cooler in the firewall forward kit from Vans. I do have a Sam James cowl.
Thank you for your help,
Steve
Steve
