Alan Carroll
I was playing with the power chart that comes in the Lycoming O-360 users manual, and noticed an interesting thing that maybe someone who understands engines can explain. I expected that the power output would always be the same at the same density altitude, since the air density is the same. However, this turns out to not be true. Consider the following examples at 6000' density altitude:
1. Pressure alt. 4000', inlet temp. 76?F, density alt. 6021'. Available MP is 24.8" (std. pressure minus 1" of loss through induction system). Following instructions on chart I get 156 hp.
2. Pressure alt. 8000', inlet temp 1?F, density alt. 6022'. Available MP is 21.3" (same assumptions as above). The chart now says I have 146 hp, even though the air density is unchanged.
Kevin Horton's spreadsheet for the O-360 gives about the same answers, 156 and 144 hp respectively. I believe the spreadsheet is based directly on the chart. The IO-360 chart shows a similar difference.
These examples are fairly extreme, but not unrealistic for Wisconsin summer vs. winter. In practical terms the hp differences are fairly small, but they could be enough to make a difference when testing airframe modifications designed to increase TAS (especially if the test happen at different times of year).
