gipsowh said:The Mistral G-230TS turbo rotary is in my mind the most attractive option vs. Lycoming. The only drawback is that it is expensive. Check it out.
Brian130 said:Please nobody get offended! If you break at an outlying field, will somebody know how to fix these engines? They sound great, but I don't know who would work on a rotary car, much less a rotary aircraft? Land at the nearest Mazda dealership.![]()
Rotary10-RV said:Mistral is CERTIFING these engines as well. They plan to produce a 3 rotor as well with 50% more displacement, should be a real GO-er.
I plan to use the 3 rotor 20B Mazda in my 10.
Kai,Baja_Traveler said:Not considering the new Renesis? I havent visited Tracey Crooks site in awhile to see how the conversion is going.
Kai Schumann
