I hung my engine today and I'm continuing on but I'm not sure if I put permatex 2 on the oil hoses themselves. I did on the fittings I installed on the engines but the directions don't say anything about the hoses other than you'll need to loosen the pressure hose during the initial start to bleed the air out. That leads me to believe the answer is no because I would break the gasket made by it. Also, with the fuel lines should I put fuel lube on them? Any help is appreciated, thanks,
Nick
Nick
