N N661DJ Well Known Member May 20, 2020 #1 Where can I find the appropriate range markings for the engine gauges on a Garmin G3X engine monitor?? Green arc, yellow arc, white arc, red arc, etc. The configuration of these seem to be, at least to me, quite confusing. Dick
F flyinga Well Known Member May 20, 2020 #2 That data will be in the operating manual for your particular engine. If you give us your engine model someone on this forum will have the specs.
