How do you determine which ones and where to buy for an 0-320 straight type but I don't see how to look them up on ACS... are there 15 different ones or are they all the same??
Call Lord tech support, they can give you a list of isolators that can be used.
Speaking generically, if you know what certified plane your engine came from, you can probably use the same isolator, but I'd call them first.
Tim
Now confused on how to set up the washers. The conical rubber mounts have a steel sleeve to stop crushing I assume but the install calls for an STD619 washer that has a center hole that will allow the sleeve to pass thru??? Does anyone have a detail of this install with -6 bolts and the washers required??
