The Orndoff video suggests that one of the engine flange lugs will be marked as distinct from the rest, and that two of them will not protrude out past the flywheel. This is not the case with my Aerosport O-320 (set-up for fixed pitch).
Also there, appears to be no distinguishing markings on my Sabre prop extension lugs or holes. The instructions say to torque the bolts in the crossing pattern (1,4,6,3,5,2). Is there any preferred orientation? Or can I just assign the number 1 to a lug arbitrarily and number around from there?
