N N184JG Well Known Member Jan 28, 2012 #1 I received my ECI kit engine data plate Friday . Do I drill and tap engine or some other way to install?
az_gila Well Known Member Jan 28, 2012 #2 Look for four small holes in your sump. It is held on with some small (1/16?) drive rivets.
DanBaier Well Known Member Jan 28, 2012 #3 az_gila said: Look for four small holes in your sump. It is held on with some small (1/16?) drive rivets. Click to expand... Alternatively, you can just use epoxy glue to put it on the sump. Dan
G Grezdlitn Active Member Friend Jan 29, 2012 #4 Somewhere in the kit there should be 4 small steel rivets with fluted shanks. The sump will have corresponding holes. Drive them gently in place with a hammer.
