Engine geometry may call for different solutions.
I have an AFP 150 on vertical sump. Many suggestions on VAF called for the cheek approach which seemed workable. BUT, now that all components are actually in place, the best approach for throttle and mixture ( for me) is the firewall between the left rudder assy and mount stiffener pad on the firewall. This gives a nice straight approach to injector levers and simple/robust cable mounting brackets.
The downside to this is the throttle cable must curve over the left rudder area, similar to the approach used on RV3?s. It works fine on my 3.
The AFP 90* elbow concept made cable connection less than ideal, so I went vertical, and your specific hardware is the final arbiter.
