tyconnell
Greetings,
RV-9 empennage, fiberglass attach points: I?ve drilled / dimpled the skins for the CS4-4 rivets per the plans. Now I?m rethinking that. I *think* a #6 screw is a slightly larger hole. Is it possible at this point to convert these CS4-4 holes so I can attach the fiberglass tips with screws instead?
Not a big deal if not, I?ll just continue with what I have.
