comanche180
Member
Doeas anyone know the max width and or height of the empennage in the canoe phase? I like to start building In my basement and then move it out. My door wall leading out of the basement is only 36” wide
The max width of the aft fuselage with the h. stab and v. stab removed is 42" and height is 37". You may be able to compress the open end to fit through a 36" door opening.
