Freemasm
Formed the forward section of the baggage compartment yesterday. Knew there would be conflict with the supplied ELT tray but probably need a plan before I continue. First thought is to notch and straddle the bulkhead former. Keep in mind, this will be an F4/four cylinder version so keeping weight out of/minimizing moment in the tail will be important. What did you past builders do? Suggestions? Much thanks.
Tray in pic placed loose for reference.
https://photos.app.goo.gl/ij3LLiaqCUWkzq2G6
