Which ELT model?
Most ELT’s would normally receive its GPS signal from a GPS unit via RS-232, such as your EFIS, so a separate antenna for that input is not needed. But you do need to provide a shielded wire to connect the GPS output to the ELT.
There should be drawing included with your ELT that shows which pin that signal is wired to.
