When I installed the elevator trim motor the actuator arm appeared to be at one end of its travel, which means that the trim tab is fully extended in one direction. I'd prefer to have it positioned "in trail" so there is less chance it can get damaged during the build. I assume it would be a simple matter to hook it to a battery, but I don't know which pins, polarity, or voltage to use. Anyone have some insight? Is this as easy as a 9v battery and a jumper wire?
