Staunch111
Quick question for the collective. What effect is there on a control surfac where the trailing edge (top) is perfect but the bottom is overbent. Vans provides guidance in rectifiying 'over squeezed' control surfaces using a block and mallet. If used in this scenario, would it not result in un-squeezing the bottom surface but then creatign a bulge on the top surface.
Can anyone advise what the flying characteristic is for an over squeezing bottom trailing edge on (1) elevators, and (2) wing. For the latter, does this also create a heavy wing?
Thanks in advance.
Thanks in advance.
