OK Gang, I am about to assemble the elevators and plan to use proseal as opposed to the double sided tape. My plans only describe the tape method. Currently my plan is to proseal the trailing edge at the same time I proseal the foam ribs and cleco the trailing edge together. Then let it cure for a few days before I rivet. So is this how others have done it or is there a better way. I'm a newbie so any advice is appreciated.
