The plans call for using CS4-4 rivets to attach the fiberglass tips to the elevator and rudder.
There is not enough clearance to use CS4-4 rivets on both sides of the trailing edge of the elevator. One will go in fine. However, once you set a rivet on one side of the trailing edge there is not enough clearance to use a CS4-4 rivet on the opposite side. It will sit proud in the hole.
How have others dealt with this? Is there an alternate rivet that works?
Tks,
Mike
Getting ready for the airport..
Tks,
Mike
