Okay, mostly I just want to vent right now. @#$% tabs on the left elevator skin!
I did the wood block thing and I thought it turned out "okay" - not cosmetically great, but acceptable. Then I looked at it closely and saw the big (5/8") crack in the top side, right at the trailing edge. It seems the length of the little flaps you bend to close out the skin in the trim tab area was too long - I trimmed them up some, but apparently not enough - and the bottom tab dug into the top skin, the pressure of which caused it to crack as I was going over it with the rivet set to flatten out the bend.
The crack is too big to live with, and I don't want to have cracks in my airplane anyway. It's also too deep into the skin to just cut it off and replace, so now I am drilling out the rivets that hold the elevator stiffeners and other stuff to the skin, and I'll order a new skin from Van's tomorrow. Sixty bucks plus shipping, ouch.
This next time around, I'm going to be smart and ignore the instructions - my new plan is to use the hand seamer to make the elevator tab bends first thing, before I complete the trailing edge bend. Or, maybe I'll fabricate a little rib to put in there instead. At least I'll have plenty of scrap aluminum available to use!
I think I'll also do the trim tab the same way, because this wood block and folded tab stuff is completely lame. I wonder why Van's doesn't just offer a little rib to put in there... I know from searching various list archives that I'm not the only one to have trouble in this area. Yet another aspect of this airplane project that makes no sense, I guess. It seems like the times when I've gotten into the most trouble with the empennage so far is when I've done exactly what the plans say and in the prescribed order, instead of throwing them out and using my head instead. I wonder how many fuselages I'll have to build before I get it right? Grr.
Okay, rant over - thanks for listening...
mcb
RV-7 emp
QB wings & fuse scheduled for October
http://www.rv7blog.com
mcb
RV-7 emp
