Mounting the elevator spar to the right and left tip assemblies. Not sure if the spar flange goes over the inboard tip assembly flange or vice versa. the flange of the spar is thicker, so I think it goes over the top and the inboard tip assembly flange goes under?. But I can make it go either way. The drawings don't clearly show it?.
How did ya'll do it? Spar flange on top or inboard tip assembly flange on top?
