I'm working on section 36 - elevator pushrods. Page 36-16 has the aft pushrod end bearings being adjusted to get the bell crank assembly in the proper orientation. I do not see that adjustments are called for in regard to the forward and middle pushrod end bearing to get the control stick base in a neutral position. I assume this is dealt with by filing down the control stops in order to achieve the full deflection
Thanks Tom. Not sure why they don't have us do that in the earlier section when installing the elevator push rods, but I guess there is a reason.
