The elevator balance should be done without connecting the pushrod. For maximum protection from flutter, the counterweights should be such that each elevator is in balance, without having the elevators connected together.My elevators were perfectly balanced, but then I hooked up the elevator and aileron pushrods, and rigged everything, and now the elevators rest in the Up position. I'm wondering if this is OK. Are they supposed to be balanced without pushrods connected or with?
My RV-7 left elevator counterweight seems light as my trailing edge balances lower than even trail (and they aren't painted yet). Is this normal? I haven't installed the fiberglass tips yet. Will that make the front portion heavier when I do that or will I have to add weight? It doesn't look like it will take much weight to bring the balance forward.
Thanks Brad! I'll do that.Dave,
My left elevator counterweight was also light. Installing the fiberglass didn't change it much, if at all. I haven't riveted the tips yet, but before I do, I will add some weight to balance it properly. I've read other posts on here that others have also experienced a light counterweight on the left elevator. There are also posts on installing a platenut at the tooling hole of the counterbalance arm to allow the addition of weight after painting to help acheive perfect final balance. I plan on doing this myself. Don't worry about it and keep on building.
Brad
