TerryWighs
Left elevator seems to need alot of weight added (none has been removed), and I pressume because of the electric trim...Right elevator will need lead removed.
Question: balance in trail by removing lead while the Rt.and Left elevators are connected at the horns, or should each seperate elevator be balanced individually??? When left and right currently connected, from a small amount of lead removed from the rt lead wt....it is balanced in trail. Is this adequate and correct???
