JokerF22
Member
Morning All-
On 09-07 step 5, I?m supposed to match drill #40 through the trim tab spar into the trim tab hinge. However, my E-01405 spar only has #30 holes. I?ve looked forward in the plans and confirmed that I?ll be installing 3-3.5s in those dimpled holes later on, so I?m confused. Am I missing something? Am I supposed to do my best and just drill #40 using the #30 holes as the reference?
Thanks.
E-01405 spar
My E-01405 spar was drilled #40 per the plans, and I just double-checked that the rivets I used for that step are indeed AD3-4 (Pg 09-14, step 5). If your spar was drilled #30, you probably need to contact Van's.
_Alex
_Alex
A rare mistake from Vans i suppose. I?ll call them tomorrow. Thanks for checking.
