loopfuzz
Just thought I would share some details on a electronic flap controller I created for my RV project. I wanted something that was simple to use but could still do some extra bells and whistles if I wanted it to. I'm currently using the infinity flight grip with the small flap switch they provide. I added a video to give a little idea of how it works.. here is a description of some of the features.
- Auto shuts off flap motor after flaps are fully retracted. (user settable) So this saves your flap motor from running while in the up postion. It does this by knowing how long it takes your flap motor to run to the full flap position.
- Allows you use a small stick mounted flap switch like the "Flap Control Circuit Board" sold at Vans for $40. But this controller also does alot more.
- Pilot and co-pilot both get their own flap switches. and the flap controller figures out any conflicts. So it works good on the tandem seat RVs.
- I designed it to work with the Vans flap motor but could work with any flap motor.
- Only cost me around $80 for me to put it all together.
Some extra features I added are:
- Auto deploy flaps to half by clicking the flaps down switch 2 times quickly.
- If at half flaps already, click twice again, and it goes to full flaps.
- OR instead, if you wanted full flaps down instead of half flaps, just click 3 times.
- during the auto deploy of flaps, if you hit any button, it will cancel the auto flaps
- There is a setup mode for flap controller so you can customize everthing like time to run flap motor for half and full flaps. And how you want the conflict resolution with the co-pilot switch to work.
- Added extra relay for external device control when flaps are in down postion. Currently I use this for my extra landing light. You can configure this option in setup mode to set this light in flasher mode, so it's kind of a wig-wag type light.
Let me know if anyone is interested in something like this.
Here is a link to the video of it working in action:
http://www.youtube.com/watch?v=H2L0EPofPeI
