Brett H
Active Member
Patron
While working on installing the wiring today, I noticed that one of red heatshrink bands that marks the installation location on the length of the wiring slipped.
Can anyone verify what these lengths should be?
I currently have from the end of the connector to the red band:
WH-00050 Transponder 12 inches
WH-00051-1 Com 18 1/2 inches
WH-00095 ADS-B 14 inches
Thanks.
Brett
Columbus, IN
Brett -
For reference, on the WH-00046 wiring harness the first red band is located approximately 23" from the connector and the second band is located 62" from the connector.
John:
Thanks for your response.
Regarding the location of the red band on the antenna cables, I asked Van's and got the following response:
WH-00050 Transponder Antenna Cable 12" from the non-BNC connector and 38" from the BNC end
WH-00051-1 Com Antenna Cable 7.5" from the BNC connector
WH-00095 ADS-B Antenna Cable 11.5" from the BNC connector
It was very helpful that hear that the red bands can slip. Because, mine did.
Brett
Columbus, IN
