Hawkeye7A
Not sure exactly where I should post this so, Doug, feel free to move it if you see fit. I fried my (standard Vans) alternator a couple of weeks ago which also took out three other instruments. I replaced the alternator with the Plane Power unit (a TRUE drop-in I might add!) and the three instruments. All systems are go now but I noticed a strange anomaly (which I'm ashamed to say may or may not have been present with the old alt; I never noticed) but when I'm idling or for what ever reason have low manifold pressure indicated, when I press the PTT the manifold pressure slowly climbs to 25-28 (depending on how long the PTT is pressed) and then when released, falls back down to the former reading. All during normal flight operations the MP seems to be working fine. I suspect some sort of ground loop or something. All of my comm audio is shielded cable including the wiring to the PTT button and everything else is working fine. I have no interference with any of the comm or intercom. It's just this one wierd quirk. I have the standard Vans MP gauge with the sending unit. Any ideas, anyone? Thanx.
