woodyweaver
I'm New Here
I just bought an RV3 with no starter. I want to add one. I think I have it figured out except for the flywheel. Any advice or information would be greatly appreciated.
Woody
Woody
Woody
Simple, just order a Sky-Tec Flyweight starter, making sure you get one with the correct number of teeth.
It will bolt right on your O-290, w/ no issues. This assumes your O-290 is not a former GPU, I'm not sure if it will work with one of those.
BTW, you can change the tooth ring on your fly-wheel if needed. My starter ring had 122 teeth so that's what I ordered.
