Jared_Solomon
Hey All,
I just finished installing the electric aileron trim in the right wing of my RV-14A. A couple of things stuck out at me as odd and wanted to get some feedback from others.
1. After mounting the trim servo assembly and test fitting, i noticed the springs rubbing against the push/pull tube. I had to bend the servo arm up about 35 degrees in order to lift the springs high enough so they wouldn't rub against the push/pull tube
2. I've noticed a bit of flexing on the access cover and surrounding skin where the servo is mounted when moving the aileron through it's full range of motion. Are others finding the same thing?
Thanks!
Thanks!
