Doug
Perhaps this is a dumb queston and I am not seeing the obvious but I am uncertain how to do the connection between transducers and wiring harness. Perhaps too much knowledge is my problem here but not using shielded cable on low voltage sense circuits in a high EMI/RF environments is just not right.
How have folk actually joined there transducers to the harness? Is it a case of stripping the two wires, twsting, solder and heatshrink and forget or do others do it differently?
How have you dealt with the pull up resistors necessary on some channels, do I simply solder these into the harness and heatshrink over or is there a better way.
I have not read reports of interference on transducer inputs when transmitting as occurrs with some vans gauges so maybe I do not need to be concerned.
Doug
Doug
